lordgaz
- Dec 8, 2015
- Location
- Herefordshire UK
- W220 S-Class S55 AMG 2000 / W220 S-Class S55K AMG 2003 / W163 ML270 / Jaguar XJR X350
Hi All
I have a little bit of a problem.
I stopped using my S55 about 14 weeks ago, and put a cover over it until just recently - It just will not turn over.
All the dash lights come on, and everything is as per normal until I turn the key, and nothing happens (key turns, fuel pump primes etc)
There are some things I have checked and things I have found!
1 - I put a new battery on
2 - I have checked all fuses in the engine bay (including the ones under the drivers carpet and on the passenger A post area) - all seem ok
3 - No clicking from the starter relay - Swapped it, and still nothing.
4 - Checked the TCM (the one in the right side fuse box as you look at the car from the front - It was full of transmission fluid(!!) - cleaned carefully and put back - My Carsoft MB11 can seemingly connect to this module still (It will show me the part code, and other gearbox data information - eg - gear selected, solenoids info) - but it does show 2 codes - P02311 / P02312 which is a canbus error
As it was full of transmission oil, I guess I can presume the pilot bush coming out of the gearbox is also wet - Could that be a source of the error code? -
The car is also flat on the ground as over the 14 weeks, the ABC suspension has sunk, making access underneath very hard.
So I guess I would like to know of anyones experience with these error codes, and also suggestions of any other tests or checks I could do before I throw the towel in
edit: I also suspected the starter motor could be jammed, but without any clicking from the relay, sort of ruled it out - plus I manually turned the engine a small amount in the right direction with a socket on the crankshaft to see if that would help if the starter was stuck
Failing that, I will need someone with mobile star diagnosis in the Hereford/Worcester/Gloucester or beyond area who knows their stuff - Recommendations welcome.
Cheers
G
Cheers
G
