lordgaz
- Dec 8, 2015
- Location
- Herefordshire UK
- W220 S-Class S55 AMG 2000 / W220 S-Class S55K AMG 2003 / W163 ML270 / Jaguar XJR X350
Hi All - When I stopped the car at home the other night, I remained in the car whilst reading my phone and after a short while I noticed smoke coming from under the bonnet. the cause transpired to be the rubber topped dipstick pushed off the ABC fluid reservoir, and pentosin fluid sprayed on to the under side of the bonnet, and leaking onto the engine (hence the smoke) - Next day I checked for faults with car engine off - Nothing showing. I filled the reservoir correctly and ran Star test (Xentry or DAS - I am not sure as I have only just aquired the C4 and toughbook) - No faults. I think I managed to perform a rodeo test though I am unsure if it completed. Switched off car and waited for a few minutes - No ABC fluid overflow.. But again today I open the bonnet and find the ABC fluid has overflowed again and is reading higher then the top notch. Is this accumulator related? (can they be checked with Star?) - Is there anything I can be doing with my Merc diagnostics which could help me narrow down the problem?
Many thanks in advance.
