Right, bend over, this is going to hurt you a lot more than it will me...
Ooooer! :lol:
.... Of course my warrenty wise dose not cover air suspention thats typical that is.
Is your suspension air or hydraulic?
Hydraulic. Well I'm assuming so as he said SBC!!!
I know, but then air has been mentioned too .....and ABC
Trouble is the 221 had both as options..!
I thought only the V8 and V12 had ABC, never seen a 320 with ABC, my 2 cents worth is the level sensor rod had seized and snapped of the rear anti rollbar..........
This is my vin WDD2210222A072936 number but can not find anything about suspension from it.
It is indeed, it sounds odd that the pump has just gone, usually there will be indications, white warnings and odd activity (including a pretty obvious noise!) before it fails completely.
I remembered just a few days ago that the car seem to lifting and dropping every now and then when sat in traffic. Could this help diagnose which part is faulty.
Been thinking on it all night and can not figure out why its not getting the 12v at the pump even when the switch is pressed....that being said will it only flick up fast which means by the time i have pressed it and got round to see the meter reading its gone?
Have found you can get a pump for £214 with 2 years warranty.
I was working under the impression that yours had ABC, it does not. Please ignore everything I've said as it doesn't relate to pneumatic systems!!!
Oh no any idea where i start now then mate?
I think may , that you had better bend over this time !I was working under the impression that yours had ABC, it does not. Please ignore everything I've said as it doesn't relate to pneumatic systems!!!
