W221 DAB experiment
Botus
S500/2010/500
DAB was optional on the W221, its a separate module, sitting on the fibre MOST in the boot.
I never got why these were unaffected by the Feb 2016 great UK reshape of the DAB network that wiped out most C and E class models. On mine Signal drop out actually improved to never since the change (but had been petty good by 2015 anyway).
But now I realise why it all got better. Its a DAB only tuner not a DAB & DAB+ tuner. So the >99 channel list bug didn't hit these and as less where broadcasting on DAB the signals for the remaining channels picked up. But one day we'll have no broadcasts. Germany killed DAB broadcasts a few years ago and the UK is one of only 4 countries left that still dual broadcast both digital signals (out of about 50 that do DAB).
The stock DAB tuner staggered me with its the quality - its like a great FM broadcast, not some hollow compressed low bit rate embarrassment. And it sounds just the same quality as the other components like the Radio, DVD player or TV… But then the tuner is £600 to buy
index.php
Not that I need it... I just wanted to play over Christmas. I decided to look at an upgrade to DAB+. Mooching about on ebay, I came across the current tuner from a w222 for not much money and saw its connections were the same as my car. A single black multiplug with 2 MOST wires and a 4 pin connector (using 3 of the pins on the loom). With the Antenna on one Fakra (always using just the outer one, the inner antenna connection was for Band111 which everyone stopped broadcasting when DAB+ came out). However I was informed the w222 tuner won't work, the world moved on with later cars running "MOST High" (and I believe they have some anti theft chassis number issue too).
That disappointment made me remember the E class tuner is yet another module out there.... (in fact there are three part numbers for the C and E class) with the current part number being... 1669003407 (giving hardware 1668202089)
index.php
Being so cheap I thought I'd have a play.... (£50 vs aftermarket in-digi DAB+ tuner that is fully compatible at £400)
On the Merc Tuner I wanted a later one as they all need the software update as they became useless post 2016 (with all iterations running obsolete software from 2011), paid £20 more and got a 2015 part that I figured coming from a new car that still had 2 years of warranty remaining its more likely the car got the Oct 2016 DAB software update that all C and E class cars need.
It was Plug and Play fitment, turned the car on and found everything OK on Comand with FM radio playing. (I once fitted the later iPod kit using the earlier loom and the Comand was dead and the rear heater controls were both offline !). Went to DAB menus and I'm just getting the search message (as per picture below). But my house is in weird dead spot, so not sure if things will work but at least its shows the screen and the rest of the car is happy. But I had ice forming on the screen, so decided I can't be bothered to go for a drive...
index.php
Overnight I think is it
  • the >100 channel bug killing it,
  • a weak signal,
  • or just not compatible,
when I realise as the MOST must be OK with it there, maybe I can find what it is with my Autel kit, and I'll know if the car's really OK with it there and what software its running
index.php
Bugger, it was never updated !!! but it is the part I expected (half a result)
Go for a drive today with the same spinning, Please wait message.... and as I get out of the dead spot on comes a DAB only station.... but no change in status on the display... 20 mins later still no change and I can only drop right down to heater controls or up to select another source. Then I park up and try the comand knob, to see if the presets to work. Nothing. About to give up when a Traffic message cuts in. I can see who's broadcasting that on the pop up (and I can hear it) and can cancel with steering wheel buttons just as before.
Then remember the phone keypad is how you set the preset memory and that works, and I can swap out different stations....
index.php
But now the bad news....
  • It never gets over the spinning please wait message
  • I doubt I can flash the 2016 update as its not supposed to be in my car
  • But the worst issue its is hideous. What a piece of garbage, these are £380 new and the sound is cheap and disgusting.
  • Its totally at odds with the rest of the car its like you got on a base spec mk3 escort
  • The Stock DAB hasn't dropped out in years, but this was dropping 4 times in a mile and now and then with additional odd background clucking and hissing noises. Then you turn up the vol and everything seemed OK but its budget cheapie not the quality tuner they are supposed to run.
  • It actually sounds like I expect DAB to sound (aka compressed low bit rate trash) whereas the original one is stunningly good
B
Botus
S500/2010/500
  • #2
I was putting two and two together as I explained my findings to a mate....
Comandonline in a couple of posts about DAB issues suggested there were two sperate software updates to this 1669003407 DAB tuner, both released in 2016
This would fit with the very same fun Peugeot were having.
  • All cars built before early 2016 couldn't cope after Feb 2016
  • Mid 2016 cars got an update to DAB+ (did it enable DAB+ or just tweak to cope with UK restructure?)
  • Late 2016 subsequently a >99 channel reception bug fix was released
On a Pug without the updates the whole entertainment systems reboots in a 4 minute loop when >99 channels found
On a Merc the DAB module locks up, but you can revert to other stuff
On a Ford there's a logo fault without current software and on the Mk4 Nov 2020 they resolved the buggy clock / data issue many Merc's face where post April 2019 WNRO its broken
On a VAG with one version, put 2018 or later Sat Nav maps on the car and ONLY IN THE UK the radio goes in a 2 min reboot loop (as as the rest of Europe is OK, VAG have not resolved it). Makes me wonder if it does a firmware update and the DAB is the driver of the crash
B
Botus
S500/2010/500
I just thought of something interesting....
there was talk about a potential Antenna change to improve reception around the OCT DAB final software update with some owners able to get software and antenna changes
if you look, as std the car's all came only using the outer antenna connector as per the picture above. With the inner connector never used on a Merc in the UK and with its intended purpose deleted (DAB band 111 worldwide switch off during the 2016 restructure), did they repurpose the inner connector with that last software update and the antenna hardware change? Otherwise I don't get what they would have done on the antenna that could help
FiveAlive
2011 E350CDI
Please keep the thoughts and tests going. My 2011 W212 has the DAB-only tuner. As it stands I'm in no rush to replace it with DAB+ as I can receive all of the stations that I want to listen to, but as you predict that will change some day and your investigations are blazing a trail for me, and others, to follow.
Alfie
Surrey/Cotswolds
www.comand.co.uk
Some models require an antenna amplifier upgrade. It may well be you just need to change the antenna amp(s).
Alternatively the in2digi tuner is a direct swap for the factory tuner and will give you DAB+. P.s the price has come down ;-)
B
Botus
S500/2010/500
I was searching for Antenna stuff, wow, on a w212 about 8 bits in there none pointing me towards anything at all to do with DAB
GPS
AM FM 1
Filter 1
FM2
Filter 2
TV
Bluetooth
Phone GSM
Taxi roof module
and none seemed to have an updated later part I can find. I did discover they have put tuner hardware 1668202089 in to lots of parts with one on older 2010 software and one having later software from 14/09 with part number 1669009513
But either way they all need a poke with dealer kit to get over changes in 2016
antenna
https://nemigaparts.com/cat_spares/epc/mercedes/1/fg/212025/d01/82/346/
B
Botus
S500/2010/500
it says some got the exact S class tuner I have, but whilst the part number is the same it has HW2048701896 rather than HW2048703694, so something is muddled.
