W221 DPF pressure sensor position on my car
Malcolm Johnson
East Yorkshire & Suffolk
R230 (M273) & W221 S350 bluetec
Morning all,
Concluded from research on the net and the error codes I'm reading and increased frequency over the last 10 months my My DPF pressure sensor is on its way out.
i'm wondered if anybody knew the sensor position on my vehicle ?
Best regards
Malcolm
Cole@MBS
www.mbssouthampton.co.uk
It behind the engine behind the silver heat plate if it’s a 221, back of the air box if it’s a 220?
M
Malcolm Johnson
Thanks for the Comments, did find the item behind the heat shield, easily accessible . Picked the part off the stealer this afternoon.
will change tomorrow morning and reset with my icarsoft v2. Curious why i need a software update?
Br
Daniell88
Registered
S350/2011/3.0
Replaced the part Thursday afternoon, error messages gone and not returning after weekend away and a couple of 100 miles, everything tip top again.
Hi , could you please tell me if I need to reset DPF pressure sensor after install and if is working with icarsoft v2.0 ?thanks
M
Malcolm Johnson
Hi, this is going back a bit, I did not reset DPF pressure sensor after install. Error messages just went when new part fitted.
