- Aug 4, 2016
- Location
- Sunny Essex
- W211/E320cdi/2009 and CLK200k 2009
That all seems very easy buddy
Sometimes it just takes having the experience of the particular fault for it to be in your knowledge bank. Electrical faults can be an absolute ball ache to fix as when it works, it works and if you have no obvious data to look at and its any garages worse nightmare.Thanks for this Steve.
This is the kind of info I would have liked from MB centre to advise, just the way you have explained above. Even though the car drove back fine and it’s been ok during test there is something in me that hasn’t got confidence to take it out as I normally would.
I will call MB centre and get a price for doing a new EIS.
Looks like a simple job but surely some coding of the keys to the eis etc is needed. Is there anything specially in relation to coding that must/not be done?
Dsk is spot on. The whole story destroys car confidence, like being 200 miles from home when it or related component just decides to give up. My dash scan is far more often and with some apprehension since my last 3 dramas.
Little NG was such a different experience, near nothing to go wrong. Cept headlights went out 2x from 5 am! Fiddlin with headlight switch sorted it. Never driven in dark before so was not aware... But.. None of that requires a f laptop or 500 quid, switch about a fiver. So absolutely no worries or apprehension. Unlike ml.
You have an icarsoft, on the EIS module page you can verify that the key has been recognised, the T15 (ignition)and T50 (crank request) states.
Similarly on the ECM page you can see the T15 and T50 states that it sees.
Should you have the issue again checking those would give you a good indication where to focus the investigation.
If you can access the back electrical connections to the EIS spray some switch cleaner onto the contacts or wiggle (very technical word) the connector to see if you have a dry connection this cured my S210 when it had an intermittent starting problem - worth a try. Years ago they talked about using aircraft spec electrical connectors but I don’t think it happened unfortunately
I’d be checking for water ingress under carpets etc. and then can connectors under front seats b
When the drains at the windscreen base are blocked, water can collect in battery compartment where there are electronics (ecu?) which can be damaged. That's what I was told by mechanic when I had same issueThanks, interestingly I have a thread elsewhere as at the same time the passenger side carpet became wet which, I only noticed due to strange condensation on the windows. They said they cleared the drains but I’m not convinced as the drivers side doesn’t clear easily, yet the exit by the wheel arch is wet as you’d expect when it rains. The passenger drain exist is bone dry. The passenger carpet still gets wet despite me drying it out. Door seals etc all seems fine and it’s not coolant as coolant level is spot on.
What would be under the passenger side carpet? I thought it would have just been seat electrics which happen to be work fine.
