W245 B180cdi
Bstone
Registered
W245 B180cdi
Hope somebody can help with this, our 2009 B180cdi has recently developed a heater fault. The heater always used to get hot within half a mile and was brilliant but now it's taking quite a long time to get going although it does work in the end. After some research I think there must be a fault with the electric/auxhillary water pump. However, the first problem is that I can't even find it, I suspect it must be somewhere under the plastic cover below the wipers, but I don't want to strip it all out only to find it's not there.
If any one actually knows for sure or has even replaced this item, I'd much appreciate it. Thanks.
