w245 battery dies every night.
DREAMER NO2
W124 2.6E M103 1989
They are repairable and you can check this out on youtube also ..Its the best way to do it ,,no one can explain to you how its done and its quicker to see it for yourself. But the price of a new one is worth checking out first .
B
baber
Birmingham but from the north east
w169 a150 petrol 2006
  • #24
theres theres someone local to me selling one for £35. just wanted to know if it matters if they are from petrol/diesel/a-class/b-class etc or if any coding would be required?
DREAMER NO2
W124 2.6E M103 1989
The number will be on your old unit. And it is so important that the new part will have the very same number so it will be identical to yours . It might look like this
ZZZZ
As above - no coding (as far as I know), but must be the same part number.
Here's a proper fuse assignment guide, unlike the "dumbed down" consumer version you find in the battery compartment - I found it extremely useful (169 is slightly different) - some of my gadgets are powered from unused 15R slots, which I wouldn't have known about otherwise.
And relays :)
  • W245 Fuse assignment of fuse box in interior compartment.pdf
  • W245 Relay assignment of relay and fuse box in passenger-side interior.pdf
ZZZZ
Just in case you decide to be brave and repair it ... ;)
It's not too far fetched, you know - I once got really upset my car didn't have adaptive brake light system, so designed and built my own. Had it manufactured by a top electronics outfit, even tried to make it into business, which ended in disaster of course, given the cost :rolleyes: but the gadget works perfectly well nonetheless o_O
  • W245 Wiring diagram for interior relay box (K100).pdf
  • W245 Wiring diagram for signal acquisition and actuation module (SAM) control unit part1.pdf
  • W245 Wiring diagram for signal acquisition and actuation module (SAM) control unit part2.pdf
mersum1es
Finland
Cars usually has options/equipments coded in SAMs (of course depending which SAM), and if certain option is missing in sam configuration, it won't be able to control it. Car will run ok but you are missing some equipment functions - differences of donor car and your car (for example rear sunshade, powered tailgate etc). I am not famiiar is there any difference in W245 options.
B
baber
  • #29
And relays :)
thanks very much for these.
as for repairing the Sam unit, I haven't got the tools or the space or the knowledge to do board repairs. although I can see no signs of damage to the circuit board.
I have ordered another sam for £30 delivered.
B
baber
  • #30
so I got the new Sam unit. fitted it. still getting a fluctuating reading upto 1.4amps.
does the sam unit control anything in the engine bay at all?
driving me a bit crazy now.
unplugged 1plug from the same and getting a steady reading of 3milliamps.
@GLK I have looked at the wiring diagrams, but I'm no electrician so don't really know what I'm looking at, but I think the plug is E3 as I matched a few cable colours to that which looks like the circuit for all the exterior lighting?
disconnected all the lights, will go and check the meter in a bit.
B
baber
  • #31
this plug is the one where I'm getting a draw from. as said I think it's the one for the lighting circuits?
ajlsl600
france
I'm stuck on trying to remove the dash at the moment. its all loose and moves about but feels like there are some clips holding stopping it from coming out.
making a water tight car ,should NOT be rocket science.
DREAMER NO2
W124 2.6E M103 1989
No but the older they get the more chances for window and roof seals to let water in . I use a produce thats made for caravans on my screen seal ,, name of is Captain Jacks Creeping Crack .And no this is not an April joke ha ha . It is white going on but goes clear as it dries and serplus can be removed . The first sealer i used was brilliant ,and that was Comma Seek and Seal if you see a tin of this its worth its weight in gold. ☮☮☮☮
ZZZZ
E3 is normally a left rear light assembly?
Here's another couple of files, to make it clearer ... or more muddled as the case might be ;)
Also found dash removal WIS - obviously under a different name haha.
  • Colour designations in wiring diagrams.pdf
  • W245 Exterior lights wiring diagram.pdf
  • W245 Abbreviations of signal and circuit designations for wiring diagrams.pdf
  • W245 Location and assignment of line and plug connectors, engine compartment, right.pdf
  • W245 Location and assignment of line and plug connectors, interior compartment, right.pdf
  • W245 Location and assignment of Z connector sleeves - cockpit.pdf
  • W245 Location and assignment of Z connector sleeves - interior right.pdf
  • W245 Remove_install instrument panel.pdf
ZZZZ
Never heard of either name, saving your post for future reference, thanks!
DREAMER NO2
W124 2.6E M103 1989
We used a lot of this C/J/C/C in the caravan repair shop where i worked back in 2000 .Caravans are ok from new , but after a few years on the road, and sitting in the hot sun, like down the coast .The sealant dries out,, and when the van is towed it will opens up the seals along the awning rails. Every caravan that i owned ,, up to 2018 i used this sealant on it to seal the awning rails. The job was done every 12 months brfore i put the van away in to storage for the winter. Selant is very good today but i found it was the rail side it would split away from first and part company .We are only talking minute cracks . The sealant from Comma was the best one, it went on clear penetrated the crack ,even ones you could not see .And then after it had cured you removed the excess off the screen with white methalated spirits ,but i have used white spirits as long as you neutralise it after.
Xhemal
A180/2005/W169
found that the Bluetooth module (I think) its fried. that's 1 thing done.
there was a bit of a puddle in the rear foot Wells. but all underside of all the carpets were soaking.
I belive this would have come from the heater blower intake so I'm currently stripping out the dash, then will take a look at all the electronics on the heater system.
will take a look at the altenator later on. View attachment 56869 View attachment 56868 View attachment 56867
where did you find this ? I have battery drain too, maybe removing this will stop it ?
