Agree with you. I think that for starting 130 bar are enough. Now I'm trying to access the relays box but it's a real messare you kidding?...
215bar should be enough.
LOLNo.
If it is a common rail direct injection (CDi) then it is that high a pressure...1600 bar.
Do you exclude the relay of the fuel pump? It starts some times, others not (only cranks)So it is not fuel pressure/pump related.
I would check next if crank and cam sensor are getting sync (though that should trigger a fault).
No, it is a sensor, not a heater!Is this sensor for heating the diesel fuel in the winter..?
Only at high rpm, high load. At low rpm or idle its 200-300barNo.
Yes +1 check for cam/crank sync during non star, star will show you but a good aftermarket tools should also.well in diesel relay rarely is problem, and in malfunction it won't let pressure rise at all. If there is enough pressure to allow injection (~150 slightly depending which engine you have), its not pump related. Next possible culprit is problems with timing = crank sensor or cam sensor. If sync is confirmed, that also allows injection to start. So next thing is why injection is not happening... I am not familiar with OM640 engine and its fuel system, OM646 engine has a fuel temp sensor which fault may prevent starting. If OM640 has one, see what reading it is giving.
That really is annoying, we get it all the time!Thank you all really for your answers. I explained not so well the problem. I don't know if cranking there's enough pressure to the rail. Because unfortunately when I tried to watch with diagnosis live data it started immediately. Even today it started perfectly. My suspect is that when it doesn't start the fuel pump is not activated at all by the faulty relais.
As soon as problem comes back I'll update the post
