122sportx
- Dec 18, 2022
- Vito W639 Brabus Sport x
Hello, last week my Vito threw a bit of a wobbler and the seal on the turbo resonator pipe popped out causing a very audible boost leak. This is a common issue and I sorted it the next day however since then my van has had no boost, an obd scan shows no faults and there’s no engine lights on however there’s definetly no boost.
Could a faulty throttle position sensor cause this? The reason I ask is that both obd scanners show the sensor at 87% even when the van is idling. If this is likely to be the cause where is a good place to source a new one? I believe it’s attached to the pedal and is a simple job to change.
