Warning lights. Any ideas
Jmelouise
C220 cdi 2015
Booked in for the 1st July. But, is it safe to drive until then? Also any ideas what it could be? Advice appreciated.
If you have Mobilio breakdown cover they might come out and scan in for you (or any breakdown cover ?)
What does the owners manual say ?
EmilysDad
Bury Lancs
ML350
as both the ABS & 'traction control'/ESP warning lights are on, it suggests that your car doesn't know how fast each wheel is going relative to each other. Likely that a wheel speed sensor has failed. You need a scanner to determine which one.
Safe to drive BUT ..... bear in mind you won't have ABS or ESP .... just like in the olden days :cool::cool:
brandwooddixon
Wolverhampton
S63 Coupe 2014
Safe to drive. If the lights do not come back on if you run the car for a bit and restart it then this may indicate low battery performance, otherwise as said it will be an ABS sensor or reluctor ring issue.
Jmelouise
Jmelouise
C220 cdi 2015
There was an advisory on my mot for a steering rack inner joint, could this be something to do with it too?
The lights are off again. So that’s good, for now at least.
