Warning Lights Bas Esp/window Regulator
mariag
Can anyone help! I have an ml320 and today the warning lights came up on the dash ESP/BAS,ETS,ABS brake pad and Red h/brake light and a buzzer sounded I was in traffic and pulled of the main road into a layby turn't the car off and re-started and the lights went out.......... got to work ok car started fine then on the way home the BAS/ESP and ETS lights came on! any ideas what is causing it?
Also my drivers window wont go up or down there is noise coming from the window motor and I had new switch pack done last year any ideas?
Cheers
mariag:confused:
I think that you need a new brake light switch for the ESP and BAS fault
M
mariag
thanks malcom
do you know where to locate the brake switch? and do you have any ideas what could be the problem with the window?
mariag
Caravanman
Newquay, Cornwall
ML320/1999/320
Can anyone help. My ABS/ETS light comes on and when I took a right hand bend the car juddered and the yellow warning triangle in centre of dash flashed. Brakes have been changed recently. Any ideas? Thanks
Have you tried it again after a re start
