Warning Lights
jerry1
london
I guess this has been asked before but I can,t find it; Is it possible to turn off the engine diagnostic lamp warning light? Can independent MB servicers do it. I,ve a W203 x reg C240.
jerry1
london
  • #2
Do I assume the answer is no on both counts. Or if you correct some faults the light goes out anyway. Anybody?
jberks
I assume it goes out on its own or can be reset by the mechanic's computer.
I don't think there is a way from the dash although disconnecting the battery for 30 mins would probably do the trick.
190
Banned
Scotland
Are there any malfunctions showing up on the display? You would have to repair these faults for it to clear.
pascal
near Dublin
sl320/1999/3.2
The battery trick sometimes works (usually if it's done early)
These light are very sensitive.
More times than not when brought back for dianostics, there is no problem and it is just reset.
But if it re-occurs after re-set, I would be inclined to look into the cause of it more thouroghly.
