Warning messages -help please
monet208
yorkshire
C180K Coupe 2003 40000miles
een getting infrequent warning messages on display eg, SBS, Light Sensor and most often -once or twice a week just after starting - Alternator Visit workshop (in red text)
But these items are Ok
Had alternaor by specialist in particular checked and was told its OK but suggestion was made to have ECU -whatever that is - checked
If its faulty can it be repaired or do I have to replace - if the latter can anyone help with a part number please
David
This could be a SAM fault David, there should be something shown on STAR
M
monet208
yorkshire
Thank you
Sorry to be dim ! But this is my first new car when I bought so afraid I do not have a clue what a SAM or a STAR is -would you mind clarifying please and how I can get these checked out
Thank you
Cole@MBS
www.mbssouthampton.co.uk
Agree with Malc, seen this a few times now, new front SAM, that is the front control module which holds you fuses, its just a thinking fuse board is the easy way to explain it!!
M
monet208
yorkshire
Thank you
Thank you for such a helpful reply pity I am not near you to give you this job
Despite not knowing the modern car terms I am reasonably practical so can you tell me if it is easy to replace and where do I find this SAM ?
David
Cole@MBS
Under your bonnet, o/s inner wing, there is a cover with two twist locks, remove, there your find a box with two sring clips, under there is the fuse board, under that is the SAM, its not a straight forward to replace and needs coding once replace!
It is easy enough, but it does need to be programed or it will not know what the car has
M
monet208
yorkshire
Thank you -both of you
Is there a site where I can get the part number from ?
Will let you know how it goes
David
carnut13
Nr Sherborne, Dorset
R231 SL400 & Audi A1 Sport
Hi and welcom to MB ownership
Please by all means be DIY on your new MB but please do an aweful lot of reading beforehand. Search threads on this forum
As Malcolm says you can do what you are intending BUT it will need reprogramming...ie on STAR ,so you will need a main dealer or good indie to get the job finished
Tread carfully:rolleyes:
M
monet208
yorkshire
Thanks again
I have a good inde locally who can access s/h parts and new so will let him do the job
David
