Washer fluid Sensor
delboy777
KEITH, MORAYSHIRE
2001 W203, 220CDI Elegance Full Leather/Sat Nav
Does anyone know how to change the washer fluid sensor in a c class 220 w203
delboy777
delboy777
KEITH, MORAYSHIRE
  • #2
Nobody ???:(
Cole@MBS
www.mbssouthampton.co.uk
Look it up for you in the morning sir!
Ellsy Tanners
Mars
Hi Del,
You need to remove the plastic wheel arch lining trim at the front. Its held on by 10mm screws and plastic spread pin clips. Will make it easier with the wheel off.
You will see the washer pump(s) and level sensor. If i remember correctly its pushed through a rubber Grommet.
delboy777
delboy777
KEITH, MORAYSHIRE
Thanks Ellsy, the ****** sensor only costs £11, so i will order it and wait for better weather before i do it:D
Ellsy Tanners
Mars
Dont blame you Del, Fiddling around with wheel arches is no fun in the cold!!
Some parts are surprisingly cheap, others are terrifyingly expensive!!
