Washer in tailgate flooding... - More entertainment from Mr
Status
Not open for further replies.
Anonymous
I am still trying to get to grips with spannering this car. It was good value at £4k, but has its problems. When I operate the washwipe on the tailgate, it works only in bursts or pulses, is this normal?: It also leaks from the RHS headling, soaking the rear seat back and headlining. I removed the headlining and tried to seal the join in the pipe but to no avail.
Andy Cottrell
E300D 1994 Diesel
Similar problem with mine. Had to replace the pipe at a point behind the headlining (cut and inserted pipe joint 8mm from memory).Then added new pipe through roof and rubber tube to rear washer. Old pipe had split where it went through rubber tube. It took longer taking all the pieces out to get access than to do the job.
Good luck.
A
Anonymous
Thanks Andy. A whole weekend job me thinks....
Status
