Washer jets adjustment
Tony sirett
Worksop
2011 mercedes-benz e-class e220 cdi blueefficiency avantgarde auto
2011 E220 S212, any special method for adjusting the screen washer jets? Mine squirts onto the wiper arms, Think I read somewhere that you need a special mercedes tool
mioba
Nottingham and Köln
Yes its called a pin. Make sure they are not blocked before you go prodding. Loosen off the hose and blow back.
The pin should be used carefully to move the jet only. Too much force and you will ruin the jet.
T
Tony sirett
Worksop
Thank you, so the same as most other cars then, holes not blocked just poorly aimed, so just put a pin in and move to desired aim.
Chrishazle
Nr Ashford, Kent
If you do, PM me, I bought one for my S204 - wrong! Yours for the P&P!
Headhurts
Norwich, Norfolk
Mercedes GLC300 2021
As per Tony Dyson if you have the jets that spray you will need the tool as they are very difficult if not impossible to adjust with a pin.
Robin
S500 Pete
Essex
S500 (W222) 2014. Turbo 4.7 V8 with loads of toys. Superfast luxury.
Don't need to adjust mine as they are the ones with the water piped in to the wiper blade holder and heating element in the blade as well. Only problem is £95 for a new pair of wipers:eek::shock:
