Water drains.
jonclancy
Excellent news!!
Malcolm, would you have the drains literature for a W169 A150 please? We are getting a bit misted up inside having parked on cold days....
VMT in advance!!
jc ATT. capt dot co dot uk
  • #862
Excellent news!!
VMT in advance!!
Sorry cannot do that one, this will normally be the heater box filter blocked, and a new filter cold fix the problem. do clean the front drains.
jonclancy
Thanks very much for the pointer, Malcolm. We'll check it out.....
All the best
Jon
Paolino2008
Surrey
SL350 2008
Hi Malcolm, would you happen to have a diagram or something showing all the drains on the r230 (2008).
barose
Peterborough
E350 2011 Obsidian Black, CLS350 2013 Silver
Malcolm I am desperate to figure out how to clean the aircon drain on my 2007 CL500. The car is a true delight except for the acrid smell when I put on the aircon. I have changed the cabin filters and cleared the front drains but the aircon drain eludes me. If you have any suggestions it would be most helpful.
Brian
Chrishazle
Nr Ashford, Kent
You may have to wait a while as Malcolm is undergoing some pretty intensive medical treatment at the moment, has not been on here for a while and may be a while before he's well enough to post on the forum again. See the "Malcolm - get well soon" thread.
barose
Peterborough
I wish him well!
All my best wishes to Malcolm for a speedy recovery.
Paolino2008
Surrey
SL350 2008
Wishing you speedy recovery Malcolm! You have been sorely missed by many. Tough being the Messiah of all that is MB.
Best wishes
  • #870
Re th
All the best
Jon
The SL the only way is to clip off the ears of the down plug under the nearside heater outlet pipe, the rear section has to be unscrewed, Its quite a simple job.
  • #871
Re th
All the best
Jon
13enzy
Rochdale
Mercedes Benz ML 270 cdi Auto W163 2002
With all of the rain of late,if anyone wants the clearing all the drains info on a 140-107-123-124-126-201.
Checking them now stops so much damage on the heater motor and other area's.
Please ask for the info.
Hi
Anything on the Mercedes ML 270 cdi Auto w163 2002 model please
jwabber
Brighton
W124 Estate 200TE 1989
Hi Malcolm,
Could you please send over your drain cleaning papers for a W124/S124 estate (I have an '89 200TE) - water dripping in the sunroof so need to clean them all out...
Many thanks, Jon
Hi Malcolm,
Many thanks, Jon
I've looked in Malcolm's files and found this:
  • water drains.pdf
M80
Derbyshire
Usually a piece of wire would do to rod it out, something like a conductor stripped out of 1.5 T+E
