Water Drip
DMK/Happy
SE / Coupe / 2003 / C 220/CDI/A
HI, I have recently got a 2003 Mercedes C220 CdI Coupe A.In very good shape except for a water drip coming from the area of the hood release.Annoying to say the least,just had a full valet done carpets the lot,lovely spotless.Cup full of water or there about under accelerator after rain overnight.Looks like a lift job in the garage I suppose.
roadster198
SL350 R230 2009
As I'm currently finding out to my annoyance I've a leak in the boot of my SL350. I've done a bit of research for fixing my car and perhaps just your seals need cleaning and re-proofing with the product below
https://www.ebay.co.uk/itm/Nextzett...289759&hash=item3da0f4f986:g:tq0AAOSwlfxXGn3A
or you can buy the correct stuff from mercedes however it's about £45 for a small bottle.
DMK/Happy
DMK/Happy
or you can buy y
Thank you for the info.
roadster198
SL350 R230 2009
No problem. If you can stretch to the £45 for the official Mercedes stuff go for it. It's apparently like magic reading reviews on here. With the gummi stuff you apparently will have to do it a couple of times a year but will still do the same job.
DMK/Happy
DMK/Happy
I cannot stand sneaky leaks,mine is coming from under the main fuse box,or the outside rubber seal on the hood release on to the carpet,not that easy to see ,anyway help appreciated.Probably will have to go to a garage that would be interested.
The leak by the bonnet release has been discussed on here previously.
@Uncle Benz has posted a few times IIRC
Uncle Benz
West Sussex
Mainly Mercedes
It’s almost certainly the bellows seal on the bonnet release cable. It’s astonishing how much water can get in through it!
DMK/Happy
DMK/Happy
I can see it at a distance behind the fuse box,it does not seem to perished as far as I can tell,will a sealer around the rubber bellows do the job? Thanks.
DMK/Happy
DMK/Happy
and I would have to figure out how to apply the sealer there without disturbing the fuse box,its a long way in to be sure.
Uncle Benz
West Sussex
Mainly Mercedes
They can look ok until you stretch the rubber out a bit. They split in the lowest root of each flute
DMK/Happy
DMK/Happy
will a good quality sealer fix if applied all around the rubber and metal please?
Uncle Benz
West Sussex
Mainly Mercedes
You could try, you have nothing to lose. The rubber bellows only comes with a complete new cable. It isn’t as difficult to replace as you might think though
DMK/Happy
DMK/Happy
OK!I will seal tomorrow as soon as the weather clears,I have a plastic container collecting the drip at the moment and would not want anyone to see it,if you understand my drift,have the car a couple of weeks only,its makes me happy ,just this mean leak....ugh!!!!
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
I used silicon sealant. I put about a foot of clear plastic tubing on the end of the nozzle so it would reach. I gave it half a canister all around where it goes through the bulkhead. Gone from loads of water entering to zero (Oh No jinxed it :(:(:().
I did clear my drains at the same time, so it could have been that causing the problem. Strange thing was it went from totally dry to a good couple of mugfuls of water in the footwell overnight, with no dripping at first.
DMK/Happy
DMK/Happy
Ive just finished sealing around the cable rubber,used Weather Mate ultimate sealer,put a decent injection on, as neat as possible hope it will work,had already the drains cleared,the rubber looked in good condition though. ... Thanks
Uncle Benz
West Sussex
Mainly Mercedes
Maybe take the lid off the fusebox and check it’s dry in there if you haven’t already
DMK/Happy
DMK/Happy
  • #17
Yep did that, looks good,gave her a little freshen up around the cage and cover,everything back together again,everything clean,and neat,hope she's sorted. ....
Uncle Benz
West Sussex
Mainly Mercedes
Great stuff! Sometimes they get condensation inside the lid if water has been getting into the car
DMK/Happy
DMK/Happy
  • #19
We;ll know soon enough if its success,we'l keep positive,the car is worth the attention,I'll keep on it. Thanks
DMK/Happy
DMK/Happy
  • #20
Hi! how much does it cost to have the A/C checked and refilled and how long does it take normally?
