water in passenger compartment 1999 slk
saggs
I own a 1999 230 slk kompressor and have water in the passenger footwell.
Where i live is quite leafy. I have cleaned out any drain holes i can see
around the windscreen but the water is still coming in. Have i missed one?
Thanks.
saggs
That's great. Thanks very much I'll do that.
Cheers.
coventryslk
Coventry
W204 CDI Sport
I have the same problem, could someone advse me how to fix the water coming into the footwell
I have the paper for getting the air intake off so that you can clean it out, the box drain as in the picture must come out from under the car near the bulk head and gearbox
The problem that I have there is nothing listed for this on most cars the drain comes out just at the bottom of one of the front wheel arches, but the liners may have to come off to see, that is if there is no pipe visible from under the bulk head, it is 320 in the picture
index.php
coventryslk
Coventry
W204 CDI Sport
Thank you. I guess it will be the passenger side arch liner to remove?
Ill remove the wipers and grill and have a look
Im getting a VAX to suck the water up from the carpet
