Water in the side heated mirror
Sand240
Hi guys,
Merc E240, W-Reg.
Problem 1:
I have this problem with my side view mirror (driver's side). After the week or so of snow covering on the car, the side mirror was filled with water! Yes, three quarter is with water and looks rather gold and not the normal mirror reflection colour. Being silly, which I always am, I tried to turn on the heater for the mirror. Yes, it got a bit burnt on the bottom. A lapse of sense on my part there. So, what is the remedy, and it would be good to know the possible cause of it as well.
Problem 2:
My led indicator screen showed a malfunction. It reads 'check washer fluid'. I did top it up and realise that it does not work, i.e. the water does not spray to the windshield. What is the likely problem here?
Thanks a lot for your attention and help.
The mirror is leaking, and you must change the glass, if the liquid in it gets on the bodywork, it will damage the paint
Hertfordshire Merx
A160
Auto dimming reactive fluid. Mirror glass is very expensive but you could replace it with a basic glass if your a bit strapped at the moment...
Emerc01
Dublin
W211 E200K Elegance, 2003
Im having the same problem and have been quoted "silly" money for a stealerhip replacement. I have sourced a replacement from www.wingmirrorman.co.uk. I hope to order one in the next few days.
My car: E200K 2001
My car: E200K 2001
Do be sure that they are dimming replacements.
Have you tried euromerc in my signature
Emerc01
Dublin
The replacements will not be auto dimming, they are heated - ideal when strapped for cash. Had a browse through Euromerc - very impressive. I have added it to favourites and it will definiteley be my first port of call when looking for parts in the future.
do insulate the 2 wires for the dimming so that they do not short out. the inside mirror should still work.
Another way is to remove the glass,empty out all of the fluid and use a stick on one from Halfords around £10 and the heater will still work
LYNALL
Kent
Mine did this i bought a whole mirror assy from e bay for about £80 glass from dealer was £185.
Wifes c class is now starting to go the same way, both 2001 cars
Lynall
