way of removing ignition barell
Status
Not open for further replies.
nas
I want to remove my ignition barell on my 190E , its not as easy as it seems i know how to remove it the proper way by turning key postion 2 then fitting two long pins in the slots pulling it out, but the thing is my barell is totaly messed up its not even taking the key in so is there any other way of removing it and how? :(
piestore
manchester
ignition barrel
This is quite common. The only way is to hacksaw the steering lock off and replace the whole thing. Try asking Andy or Dieselman on the Tec senction they may have a better way
Orlando 300E
Edinburgh
Hello Piestore
If you are contemplating sawing off the lock...............
You could (as a last resort before reaching for the hacksaw) try shoving a reasonably sized flat screw driver in the slot, then turning it (with the help of mole/vice grips). Hopefully the lock barrel will turn with it.
This will require some mechanical unsympathy :evil:(you will have to break the barrel tumblers), but might allow you remove the barrel once in the number 2 position as the manual states :D .
I have personally never tried this. There may be is some clever engineering that stops this from working- but there is only one way to find out!
good luck
Orlando
Spike
London
1999 SL500
...or use a slide hammer to remove the tumblers and then turn it with your little finger :wink:
Status
