Weird central locking
A
andy@pcd-ltd
Hi guys
Had a bit of weird one today that only had a quick look at that wanted to run past you guys
Car is 2008 c class sports coupe.
Press the unlock button on the remote about 6-8 secs later central locking opens. Does exactly the same on locking as well.
Also when you have the key in the ignition and turn it off as you pull the key out the indicators flash as steering lock comes on.
Then if you put key back in the ignition it will not turn and the steering lock is not released remove key and press unlock nothing happens not even indicators flash but put key back in steering lock releases and then car will start.
This happens with both keys as well.
Only did a star test and no faults present in eis etc.
Customer booking back in for new year but just wanted to see if anyone had seen this before. :confused:
Cheers
Andy
EIS or SAM, I would have a look at the Can bus on STAR
