rexemper
- Jan 5, 2007
- Location
- Berkshire
- R230 SL500 - oh yeah!
Just found out that the carpet behind the driver's seat in the SL are soaked!
My son was convinced that he left a dry hoody in there and when I found it some time later it was soaked - I thought he'd just left it there like that and he was equally convinced that he hadn't.
Anyway, that was a couple of weeks ago and today I thought I'd just check - reached down and sure enough the carpets are wet. Just on the driver's side, the passenger side seems fine.
Thing is, the car has never smelt damp and I (luckily) haven't had any warning lights or issues with any electrics and so on.
I'd like to get to the bottom of it, but am not sure where to start!
Also (in case its related), I've noticed that after it rains very heavily, i can see a couple of drops of water on the rear side area, just by the small window - resting on the little platform that forms the side - not sure where that is coming from either.
I have noticed that the car is often steamed up inside if I drive it and then come back to it after a while, with the carpets being wet that makes sense now. It was mostly on the rear screen that I'd notice it, but also on the front too. Especially when the weather has been cold and I've had the heating on in the car.
Anyway,
1. What do you think could be causing the carpets to get wet like that?
2. How do I stop it / fix it?
3. What's the best way to dry things out?
Thanks a lot!
Anyway,
Thanks a lot!
