goldy
- Apr 11, 2008
- Location
- Prescot, Merseyside
- Website
- www.goldsmithmortgages.co.uk
- 2019 W213
The photo was sent by the Mrs from the supermarket.Might be the antenna seal leaking or if you you have a pan roof it could be one of the seals or drains. Sorry to hear your problems are continuing
No pan roof so theres one possibility gone!!Might be the antenna seal leaking or if you you have a pan roof it could be one of the seals or drains. Sorry to hear your problems are continuing
Thankfully not. Definitely water.It's not all that oil you've been pumping in the hinges is it?
Yes but breakdown say not that. Water not under it. Just had them out again. Thinks tailgate seal needs replacing.Do you have a roof mounted aerial?
Thank you.Post a pic of the seal and the hole you speak off. Some Rubber seals have holes to allow the air trapped in the seal to escape, but these are generally on the inner side so that water cannot get in to them.
When fitting a seal you have to make sure that it is fitted exactly as it came off.
Take off the old rubber seal, clean the rubber and the metal edge where it is fitted. Use a sealing paste that does not harden and smear some all along the metal edge, refit the seal from the top edge down, ensure the seal is pushed fully home over the metal edge, use a rubber mallet to tap it into place, making sure corners are also pushed fully home.
If you end up with too much rubber, or a hump in the rubber and nowhere to put it...just lift the bit already fitted, opposite where you are fitting, whilst continuing around the opening, and tap it down until you have lost the slack.
https://www.ebay.co.uk/itm/Carafax-...m3b186c49d7:g:qagAAOSwwY9bcWli&frcectupt=true
This one looks like a good bet to use...or ask at your local bodyshop what they use for sealing, trim, door seals.
