What engine do I have?
grumpyoldg1t
Norfolk UK
2015 B200 Sport Exec 2143cc
Looking through this forum I notice members talk about their cars as Engine codes rather than their car model. How do I confirm which engine I have in my B200d?
I've tried to find out myself but the car is a 2015 and that year engine numbers seem to have changed .
Th V5 isn't any help as the engine number stated there has no resemblance of what you guys are posting.
Ta in advance.
star
Reading
Smart + others :)
What does your log book say?
Srdl
Hampshire
GLC43 AMG 2018 (X253)
We generally refer to the model code rather than the engine unless specifically talking about the power unit. So, your 2015 B Class is a W245.
I’m not sure about your engine because the B200 either has a petrol 1595cc (M270) or a diesel 1796cc (OM651) according to Wikipedia. That says the B220 diesel has the 2143cc engine.
grumpyoldg1t
grumpyoldg1t
Norfolk UK
Thanks for your reply Srdl,
my V5 says it's a B200 and 2143cc. Under "D, 2:" it says 245G so that must be it.
Srdl
Hampshire
Yes, so call it a W245 when you want to get technical but “B Class” will mean just as much to us! Wikipedia is obviously not up to date on the engine options.
grumpyoldg1t
grumpyoldg1t
Norfolk UK
OK thanks Srdl:)
So, does my W245 have a timing belt or chain? I note this car is Ulez exempt for London but other cars I've had, they've had to be Addblue equipped to make that standard.
The W245 doesn't have addblue, so how does that work? The V5 is blank under the "Euro Status" bit but must be Euro 6 compliant to be Ulez compliant??
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
You should have an A5 size yellow folder in your car's document wallet which contains your EU Certificate of Conformity, the emissions standard is stated in box 47 and your engine type in box 21, great name by the way, my kids now call me Victor! :)
Craiglxviii
Cambs UK
OK thanks Srdl:)
If it’s a diesel then it must have SCR (Adblue, pig wee) to be Eur6d compliant. No two ways about it.
AnthonyUK
Alton, Hants
C240 estate 2002
Thanks for that Anthony, when I put in my VIN it thinks it's a BMW? Rather strange...
Are you using the VIN from the plate near the windscreen or from a document which may have a typo?
It could also be the web site so try another as there are a few free ones available.
I've also used https://www.lastvin.com/ in the past.
star
Reading
Smart + others :)
Log book should have engine number on it.
grumpyoldg1t
grumpyoldg1t
Norfolk UK
Thanks Anthony. That link worked. It says "Euro 6 technology exhaust gas cleaning" what ever that means? I've looked in the manual and in the car, no sign of addblue filling place.
So here's how to tell.
Your VIN number will start with something like WDB245xxx2Fyyyyyy
The model of your car is 245.xxx and the yyyyyy is the chassis number.
For example my SL500 is WDB2304752F0yyyyy
Model number is therefore 230.475.
The engine number is similar.
It will be something like 651xxxyyyyyy
The first three digits are the engine family, the second 3 digits are the sub model and the remaining numbers are the serial number.
Ditto with gearboxes however they almost always start 722 and the next digit describes the model and the next two digits are the variant
For example 7226xxyyyyyy is a 722.6 5 speed gearbox, xx is the variant and yyyyyy is the serial number.
grumpyoldg1t
grumpyoldg1t
Norfolk UK
  • #17
Thanks Lostkiwi.
Right then. My vin first numbers are 2462082, so from that the model of my car is 246.2.. and my gearbox (7 speed auto) starts with 724. That's clear then!
Thanks Lostkiwi.
Your car is a 246.208 - your gearbox needs the next digit added so it will be a 724.x if that makes sense.
Incidentally if you see people talking about an engine being an Mxxx it's a petrol engine, if it's OMxxx its a diesel.
Craiglxviii
Cambs UK
That means SCR. Euro 6d is specifically selective catslytic reduction for diesel exhaust gas.
What is in the spare wheel well?
