- Aug 25, 2006
- Location
- Midlands / Charente-Maritime
- '93 500SL-32, '01 W210 Estate E240 (RIP), 02 R230 SL500, 04 Smart Roadster Coupe, 11 R350CDi
Generally the injectors are good for life in indirect injection petrol engines due to much lower operating pressure compared to direct injection.
If you have an issue it can be found quickly by looking at fuel trims using diagnostics but in general if there's an issue you'll either get a misfire or engine management light.
A misfire will also often trip an engine management light.
The way the system works is as follows and was introduced in 1993 when catalytic converters were made compulsory.
On startup the ECU will see the coolant temperature is low so will start in open loop mode, i.e it won't use the readings from lambda sensors in the exhaust to refine mixture.
Once there is some heat in the system the ECU will switch to closed loop. The lambda sensors in the exhaust now monitor the exhaust emissions and feed back the information to the ECU. If the mixture is rich (too much fuel) the ECU will reduce the amount injected. If the mixture is too lean (not enough fuel) the ECU reduces the amount injected.
If an injector is faulty the ECU can't control the fuel properly so will turn on the engine management light. Internally the ECU also maintains an adaptive map of how far it has to adjust fuel from what it expects to what it had to adjust. It does this for long term and short term periods. These are called the long and short term fuel trims and if they also exceed certain values will cause the engine management light to be lit.
This is for petrol engines not diesels.
So as you can see if there is no management light and the fuel trims are ok (early warning will be fuel trims) then there is no need to do anything.
Modern fuels also contain additives designed to clean injectors. You can add cleaners for the injectors if you want but they aren't needed.
