What is this please?And what does it do?
jonnyb1
aldridge west mids
Hi,E220 1994 Estate,Hi my mechanic dropped this t shaped piece of the air inlet and parts fell out,now the car drives lumpy.
Can you tell me what it is,and what does it do?.I ask because the mechanic said it was irrelevant.
996jimbo
C43 estate
Looks to me like the MAF.
If it is the MAF this bit costs several hundred pounds and a faulty one of these causes poor running, poor fuel economy and can cause the cat to fail which would then cost even more money.
There are not many bits on a car that are irrelevant, and even less that are plugged in to something!
Do a search of this forum for 'faulty maf'.
Air flow meter or MAS - without this working you will have very poor engine response and a distinct lack of power as well as an inability to rev past 3,000 rpm. This can also cause the cat to fail (if one is fitted) if it is not fixed.
If your 'mechanic' said it was irrelevant I would recommend finding another mechanic
bundy
merseyside
i second that if he thinks its irrelevent he shouldent be messing & i do mean messing with motor cars & should stick to lego!!!!!!
LAMPSLIGHTS
CARMARTHEN WEST WALES
Lumpy running
you can get a new mas on EBAY £100.or try soaking it in brake fluid over night.A bosche dealer might sell you the middle bit only.If you cannot get the car to rev and go beyond a certain speed,that is usually the problem.
tom7035
A very necessary piece of kit! Soaking won't do any good if 'bits fell out'. Replace ASAP or it'll also cost you several hundred pounds for a new catalytic converter shortly. As for your "mechanic" (?) - get rid pronto as suggested!
jberks
As my 13 year old would say Oh My God!!! - I assume he's a bicycle mechanic?
Actually I suspect what he meant was that he knows exactly what it is and how much it costs so having broken it in front of you, has fobbed you off and done a runner. I doubt you'll be hearing from him again!
Above spot on - don't drive it much and get a new one ASAP or it can get even more expensive very quickly.
jonnyb1
aldridge west mids
Hi, many thanks ...i am waiting for the part from Dronsfield.I take your advice and wont drive it till fixed. chhers colin
bundy
merseyside
ALAN@AUTOCLINIC said:
seconded,tom, if you require this part ,and make sure you do,please check the web address below ,give me the mb and bosch part n0 and i`l see what i can do
theres always sombody on here tryin to make a few quid!!!
big x
I see new Bosch one's on Ebay for £75.Clearly prices have fallen dramatically with economies of scale.
adam
jon_harley
Well we all have an expensive habit to feed - buying mercs!
jonnyb1
aldridge west mids
Hi.used Dronsfields for the air mass meter.Fitted in seconds .....marvelous
Mant thanks from forum members and Drondsfield.
interestingly enough, the probes in my old air sensor were non existant.How on earth would they break off?Needless to say ,i didnt try to see how fragile they were in the new one, but surely they have some tensile strength. Any way cheers again and thanks....colin
