Both sides, same number. The little box with the electrical connection is bolted to the black bracket, which in turn is bolted to the top of the strut.Some kind of motion sensor on strut. Lookin at qlty of ride is it on both side or just one
Thanks for that, Tony.Airbag Sensor
OEM Number: "A005 542 1218"
Looking for a MB E-KLASS (W212) (2009-2016) Airbag krocksensor? Get OEM part "A005 542 1218" for model 2010. High quality, reliable, and available with quick delivery.www.varaosahaku.fi
apparently quite farAirbag Sensor
Apo
You're welcome, I think my favourite search engine must be pointing NNE?Thanks for that, Tony.![]()
I can see a dodgy aftermarket fashionable strut brace in your near future…So I presume it's attached to to the bracket which in turn is bolted to the top of the strut, so if I get hit on the front wing, the airbag goes off, could I move the bracket slightly, but still on top of the strut, would the airbag still work?
Correct, Russ, but less of the dodgy,I can see a dodgy aftermarket fashionable strut brace in your near future…![]()
Stick it on the oven instead…Correct, Russ, but less of the dodgy,but if it's more trouble than it's worth, might not bother,
we'll see.![]()
