What is this warning light?
Ryan-Smith
New Registration
SE London
Hi there.
My girlfriend's 1995 C200 Elegance has got a warning light on all the time.
It is at the top right hand corner of the SRS warning light and looks like a bulb with rays coming out of it.
Can someone tell me what it is, as we can't locate the handbook?
Dec
Ireland.
W202
It is warning you that you have an outside bulb fault, replace bulb,you also need to check brake bulb and reversing bulbs while someone has foot on brake.
Dec
wireman
lancashire
A common problem.
You may have a wrong (5W instead of 10W) tail lamp bulb or some crumby contact on any lamp or its wires if all the lamps seem to be working. If the lamp only illuminates after the brakes are applied it will latch on untill the key is turned off. If its a side/head or fog lamp the indicator should extinguish when the lamp is turned off.
I had several 21W (B&Qs best) lamps that worked but would trigger the fail lamp if they were installed on the car. Buy decent bulbs and your troubles will go away.
Good luck and please tell us what you find.
With the brake lamp gone that will only put the lamp on once the pedal is pressed
And that usually happens immediately upon start-up. With both of mine, I have to put my foot on the brake, before the ignition will even turn.
Dont I know it with the steep drive that I have
