What is this ?
walkenblue
cambs
2002 w203 220cdi Avantgarde
Any ideas to what this is as i found it as you see it just dangling as i am attempting to remove the cover in wheel arch to get to the fog light ? I am iffy to continue till i know what is . Many thanks. C class w203
mersum1es
Finland
Is that purple in color? In case, it's headlight adjustment vacuum pipe... Is the adjustement working (should not)?
W
walkenblue
cambs
hmm,Xenons on the car,is this purple pipe far from it's location ?
grober
Scotland
W204 C200cdi estate
YUP VACUUM PIPE probably from the headlight level adjuster-- try adjusting the headlights up and down with the small wheel beside the lighting selector switch--- one or both headlights will fail to move up and down
W
walkenblue
cambs
No selector,self leveling.May have to try at night to see if it 's working or not. I dont know how this came loose or maybe i somehow disturbed it .
W
walkenblue
cambs
headlight washer
They are ok .Unless there is more of what the pipe does.Does not seem like there is too much of the pipe to go far from where it is hanging.
whitenemesis
CLS55 AMG '05
When the front of my 203 was dismantled to fit headlamp washers there was a little vacuum reservoir attached to the cross member. Have a look/feel perhaps you have the same and the pipe connects there?
W
walkenblue
cambs
Ok will try that now ,may have to jack the car up ,not much room for a xxxl like me.
It looks to me as though the Xenons may have been added, purple is the colour for the headlamp adjusters
W
walkenblue
cambs
Very interesting that is.These were supposed to be from factory fittted from new,whitenemeseis sent me a data card and it says bi xenon headlights. ,,i have just turned the lights on and off a few times and do not see them rising up to level as what i see when i turn them on at night.,but should i see them raise in daylight ?....I am thinking the vacuum hose may have been there all along from new .
There is no vacuum system for Xenons, its all electric from sensors front and rear
W
walkenblue
cambs
So do we think this pipe is there in the loom from new?
is it down be the headlamps ??? there is a vacuum system under the bonnet
index.php
W
walkenblue
cambs
index.php
The pipe is just hanging down virtualy touching the cover as i was trying to remove the lower wheel arch cover to get to the foglight,in the photo.
Then I think there from new, and forget it;)
W
walkenblue
cambs
  • #17
Does seem that ,i will go and try the lights once it is dark enough,and report back.Thank you for the help.
W
walkenblue
cambs
  • #18
My apologies...Thanks to everyone.
thefast1
Hants
CLK 350 Sport Cab
Just a thought but if the car has Xenons it may be from the headlight washer, as they pop up and down using a vacum I think!!!!
whitenemesis
CLS55 AMG '05
They pop up using water pressure and down using spring pressure
