What offset?
ejs355
London
Im looking to replace my standard alloys on my cl500 to amg styleIII ones.(like the cl55)
Ive seen some with these offsets: front ET34 rear ET31.
I dont really understand what that means but would like to find out if these will fit my CL.
Can anyone help? either with the meaning or just if the'll fit.
Many thanks guys,
eddie.
E
ejs355
London
Thanks for the reply Malcolm, i'll check it out.
Just another question, does it matter how they sit?
What i mean is, if its within 10mm or so, does that really matter?
and if so how?
Cheers mate.
eddie
rf065
Grossbritannien
Unless you want your car to "tramline" or dictate to you in which direction it wants to travel, then stick as close to the original offset as you can.
There is also the possibility of tyres rubbing against bodywork, suspension etc.
Russ
E
ejs355
London
Thanks,
Is that the case if the offset is more or less than original? or both?
Sorry these may seem stupid questions but i havent got a clue.
Also do I ever need to take into consideration the brake caliper with these offset measurements?
cheers,
eddie.
rf065
Grossbritannien
Both.
If you stick to the original offset, you will be OK.
(see table already posted)
Smaller diameter wheels could infringe brake caliper,
so stick to same size or bigger with original offset.
Bigger wheels require tyres that keep the same rolling circumference or speedo, gearing will be changed.
Russ
The danger on modern cars is with the ESP if you change the off set then your car could mis handle
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Your allowed +/- 4mm on the offset and no more. With the CL there maybe problems with stability control and other systems on the car it the offset is wrong.
jib
E
ejs355
London
Malcolm have I just read ur total posts correctly?????:confused:
Unbelievable!! :shock:
E
ejs355
London
Right thanks.
theres so much I dont know and need to learn.
I still dont know what to do. I think I need to see a wheel with different offsets and actually see how it will look and feel on the car.
Gut feeling is to steer clear of the ones ive seen.
thanks, guys
p.s malcolm did i read ur total posts correctly??? - unbelievable! :)
rf065
Grossbritannien
Malcolm is too busy to answer as he is replying to several other posts on several other forums at present. ;)
Russ
Right thanks.
thanks, guys
When buying wheels they must be made for MB as MB wheels are whats known as Hub centric, that means that they center on a flange on the hub, and the bolts just hold them on, and have nothing to do with the centering.
The CL500 is one of the cars I love, an all time great car,
Can you put some pictures up please.
When you have been posting for a couple of years you do not notice the post count
E
ejs355
London
Well thanks for all your help and to everyone infact.
Was just very impressed by ur post count. Keep it up its fantastic!
When the cars clean in the week i'll put some pics up for you.
Thanks again,
Eddie.;)
100%Bitch
Norfolk 'n' good
Some say that when his post count reaches 20,000 his name will glow gold.
Some say that it's his age.
All we know is he's called "The Stig"
Oh God, I've been watching too much TG :shock:
Oh. Malcolm, ;)
Oh. Malcolm, ;)
At 20.000 I will stop posting and come back on with a new name.
and11
Leeds
Perhaps this is why i've been having some of the problems with 'drifting feeling' post i entered a while ago? Mb told my my wheels wern't original, despite the fact they looked original with center caps mb badge on, when i went for some new bolts.
