Ninefingermick
- May 6, 2023
- 1998 call 200 coupe petrol
Do you no what this is please?Welcome to the forum - stick arould
No need really. It’s an ignition coil, same as this…Any numbers on the other side.??
Wow. How things change, wots the I ring tube foe and why is there a hole, tube in the front? I had that as some kind of pipe junction box.No need really. It’s an ignition coil, same as this…
Ignition Coil
GSF Car Parts stocks all of the car parts, accessories, and tools that you’ll need to keep your vehicle in good shape. Free UK delivery. Shop online today.www.gsfcarparts.com
Interesting, sounds a little over complex when I think for eg! m/bike coil. Earth, ussual a securing bolt. ht and live.It has a rubber extension tube that comes out the bottom, goes onto the spark plug. An HT lead goes onto the other outlet for wasted spark onto another cylinder, for example number 4 if this one is fitted to cylinder 1 on a 4 banger. The rubber O ring is a seal where the low tension loom plug fits on. They are an unusual electrical connector
