Brian23
I am looking at a Petrol 2009 SLK at the weekend. This will be our 3rd one so I know a bit about them, but any help will be good. We only want a SLK 200, so no need to recommend others. Thank you.
That’s a great pity, as I can’t recommend one of those as the M271 engine isn’t great and at 13 years old could be a ticking time bomb.We only want a SLK 200, so no need to recommend others. Thank you.
Thank you, the last 2 we have had have been SLK200 and just sold a 2006 which was great and had no problems at all, but of course each car is different and you do not know how it has been driven etc.That’s a great pity, as I can’t recommend one of those as the M271 engine isn’t great and at 13 years old could be a ticking time bomb.
I can recommend the M272 engine as that will be late enough to be outside the balance shaft issues. Although you don’t want to know about that, so I won’t…
Thank you I will check that. It never seems to amaze me that when you lift the bonnet of a second hand SLK the Cam Mag cover is missing. MoT'd in Sep so hopefully the subframe would have been picked up. It has been ceramic coated. Good thing or bad?Check the front cam magnet electrical plugs for oil .
As you know , car should have had an oil change at 37500 miles (recommended every 40k after that )
Rear subframe can rust from the inside
Take an icarsoft MB2 with you ?
The ceramic coat might mean the outer paintwork looks goodThank you I will check that. It never seems to amaze me that when you lift the bonnet of a second hand SLK the Cam Mag cover is missing. MoT'd in Sep so hopefully the subframe would have been picked up. It has been ceramic coated. Good thing or bad?
No idea buddyYes it does look good on the photos. Does it need any special care?
Ceramic coating care: There are many different products with varying degrees of resistance to wear and tear. Around ten years ago I had a F1 Williams ceramic coat on my first MB and still I reflect on it with the thought "I could have cleaned it with a brillopad and it would still look great".Yes it does look good on the photos. Does it need any special care?
He's looking at an SLK not an SL...Leaks, Damp boot or floor and/or musty smells....
Thank you. Bought it now. I found memory seats a pain as they are sooooo slow. Much prefer manual.Full leather, heated seats (preferably memory, wish I had those!), Airscarf (essential!!). If it has Comand (NTG2.5) make sure it's had the 2009 update and preferably has the latest 2018-19 maps installed - which need the 2009 software/firmware update or latest (and last that MB will issue) 2018-19 maps will not install, and it'll cost to correct!!
Let’s have some pics buddyThank you. Bought it now. I found memory seats a pain as they are sooooo slow. Much prefer manual.
