What tyre pressures ??
T1M4
Can anyone help me with the correct tyre pressures for my car (C250TD) it is fitted with alloy wheels with tyre size 235/45 R 17 94W
As I don't have the handbook and I suspect they were not the original fit anyway I would appreciate your help.
Thanks,
Tim
There is a sticker in the fuel lid, and the pressures stay the same for any size of wheel or tyre for that car
T1M4
T1M4
Thank you, I did see the sticker there and have set the tyres at those pressures but I thought if the tyres had been changed from original to low profile then the pressures may have been different.
But all is well now
thanks,
Tim
Tim, you can vary the pressures a little either way, it depends on how you find the car rides and corners, you will find a happy medium within a couple of pounds
philharve
Falmouth, Cornwall, United Kingdom
go.to
W202 C230K Auto 2000
Tyre pressures
Tim
Use the pressures marked on the inside of the fuel filler flap as a starting point, then follow 'Television's advice, above. Varying the pressures can have a dramatic and positive effect. Get them wrong and you'll soon know it.
REGARDS
Phil
T1M4
T1M4
Thank you both I am following that advice :)
