Want to try this on my W639 Vito 3.0 v6 om642
Guess I spray it into the air pipe that screws to the left of the airbox
Is the turbo going to suck the spray and air into the engine?
I guess do it slowly in small doses
ARRRGGH! Yanks & women have periods!...... it works period.
Take the egr off and clean it .
What is the best way to create a fine mist as a diy at home? wallpaper steamer ?But do this as a very fine mist and take longer and there will be no risk of hydro locking, and a very fine mist will not hurt turbo.
How do you do that on a om642? All I can see is the air pipe that goes onto the turbo, so I was thinking about spraying it further up just after the MAFdo it past the turbo / take intercooler pipe off throttle body and put it in through throttle body
The quick fixes (bodges) rarely work without some nasty side effect.Its not hydraulic locking you need to worry about. Its the loose carbon running through the valves, cylinder bores and your exhaust that is the concern.
I have had 3 cases of the terraclean type action performed followed by engine rattles caused by valves jamming open and causing serious damage. I would never recommend it.
thanks for the adviceIts not hydraulic locking you need to worry about. Its the loose carbon running through the valves, cylinder bores and your exhaust that is the concern.
