Wheel bolt missing
Garista
France
2001 ML 270 CDI. 1991 R129 300 SL
This can't be right can it? One bolt is missing on the left hand drive drivers side rear wheel and has a black small bolt way down inside?
G
Garista
France
  • #2
Er 1990 300SL, German sold originally.
Naraic
2005 CL500.
No, not right. Can you get it out? If yes...replace it.
G
Garista
France
Yeah I will try. Thanks.
Mark A
Aberdeen
58 ML-320CDI.
Take the wheel off and the broken bit should be easy enough to remove.
G
Garista
France
Going to buy the bolt first.
brandwooddixon
Wolverhampton
S63 Coupe 2014
Definitely not right - could it be a bolt for a steel rim or a standard bolt with a missing chrome cap
Mark A
Aberdeen
58 ML-320CDI.
Just make sure you buy the right type, most MB alloys need a radiused bolt rather than taper, but take out one of thee others (another wheel) to confirm.
Most likely M12x1.5 40mm long with R12 head.
There’s a good chance there’ll be some spare wheel bolts in a small black plastic box in the boot… the box with the locking wheel bolt key in…
mioba
Nottingham and Köln
Certainly not right. Make sure you get the right one (about 3 pound at a dealers) armed with VIN
Steel and alloy wheels often need different bolts so dont pot luck it with whats rolling in the boot unless confirmed by removing a known correct bolt.
G
Garista
France
I got the bolt out no problem, it was holding the wheel on but too short for these wheels. It looks like a Mercedes bolt for another application.
I have ordered the correct type I think, Febi Bilstein.
G
Garista
France
A bout 9 euros each, reassuringly expensive!
G
Garista
France
No spare bolts in the boot, got the tool set though in its bag, it was minus the tool for manually doing the roof though, otherwise it is all there. Some nice blue metal wheel chocks with the spare.
G
Garista
France
Got two locking wheel bolt things.
Out of curiosity take out one of the others and compare.
Best thing to do with MB locking wheel bolts is remove them and chuck them in the bin.
G
Garista
France
  • #17
Yeah I will.
Don't know if they are Mercedes. Why bin em? I don't want them half inched.
G
Garista
France
  • #18
I live in France and just found out the CV fiscal is 21. Woah!
Are you sure? That's around 300hp?
