Wheel Nut Torque Settings
Paulopt2248
Can any member tell me the correct torque setting for the wheel nuts on a Merc C Class W203 with 17" alloy wheels?. I had new rear tyres fitted recently and wanted to check the nut settings.
I believe they should be around 65 LB/FT for both steel and alloy wheels, but wanted to check here.
Many Thanks,
Paul
C320 CDi
popuptoaster
south Essex
Ive never used a torque wrench on a wheel nut in me life, just use the supplied wheelbrace and do em up tight as you can, its designed to be the right length to give roughly the right amount of tightness.
Rory
Cheshire, UK
I've been using one recently, and, of course assuming it's accurate, it does the bolts up looser than I would do them without the torque wrench. I can't resist giving them an extra tweak.
Checked them a week later (never bothered before) and still seemed fine.
230K
Belfast
E300TD/1998/3.0 Diesel
110Nm is correct, i use a torque wrench when i can but remember these figures are for free turning bolts. Rightly or wrongly i alway apply a little bit of grease to the threads and the hub where the wheel centres. Leaves them easily removed.
230k
