When do you change the Timing chain on a W124 ?
Status
Not open for further replies.
Enam
London
HI,
Just a quick question, at what age/mileage do you need to change the timing chain ?
Is is every 50k or 5 years, or is it at 100k ?
Or do you just need to change the tensioner at a certain mileage ?
Any help would be appreciated.
Thanks.
E
Enam
London
its a W124 coupe (E320)
dieselman
A diesel
There is no specified mileage as this is a duplex chain. More than 5 degrees retard on the cam at engine TDC indicates too much stretch.
sunil sood
how do you go about measuring this 5 degrees retard to look for stretch?
mine is a 190e with 114k miles original duplex chain.
dieselman
A diesel
Compare the cam timing to the crank timing.
If the crank has to be 5 degrees ATDC when the cam is at the TDC mark then the chain is stretched.
Status
