Which ballast do i need
Tony sirett
Worksop
2011 mercedes-benz e-class e220 cdi blueefficiency avantgarde auto
Hi all, I have a 2011 E220 avantgarde estate blueefficiency, with HID EXNON lights, all the lights work (as far as I can tell) except the passenger side head light, I took the working drivers side out and put it in the passenger side and it didn't work, I put the passenger side in the drivers side and it worked, so both bulbs are working, which leads me to believe it is the ballast unit, I want to order a new one but I don't want to take the old one off until I have the new one, only problem is without taking the old one off I don't know which one to order, can anyone tell me which one to order please?
Cheers Tony.
I presume you've checked fuses first?
T
Tony sirett
Worksop
I assumed that the fuse was OK as both head lights work off the same fuse (I believe) so if drivers side works then passenger side should work? Any idea which fuse it it?
mioba
Nottingham and Köln
If you have a code reader or know an indy that does maybe get the codes read.
If you are sure its the Ballast look on the numerous online IPL based on vin to get the pn. Alternative ask a MB dealer or MB grangemouth.
T
Tony sirett
Worksop
thank you, i am booked into an MB service centre on the 14th Jan, for a once over to make sure i haven't bought a dog, i do have a code reader (iCarsoft) but i have lent it to my brother, who lives the other end of the country so waiting for it to be sent back.
mioba
Nottingham and Köln
Note you are in Worksop. Mercserve Nottingham are my go to to avoid MB dealers for certain things.
Even dogs can be sorted.
T
Tony sirett
Worksop
When I had my old E320 estate I always used MB Service Centre in Mansfield, I had a problem with an air mass flow thingy, they sorted it out for me really quickly as I was about to go on holiday, couldn't praise them enough.
mattkh
England
A160 W168 1999 1.6
....., I took the working drivers side out and put it in the passenger side and it didn't work,
Cheers Tony.
Sooo the problem is in the bulb holder in the passenger side.
leapfrog7
Registered
Beverley,East Yorkshire,UK
E212/2012/350CDI
I had the same problem in my 2012 E350cdi a month ago. It is worth checking the fuse first as they are individual for each side. It is located in the engine compartment on the drivers side. 10A from memory. It is most likely to be the ballast. I watched a few YouTube videos before tackling it. It is necessary to remove front wheel, part of wheel arch liner and front bumper to gain access to remove the headlight unit. It was all straightforward but took 3-4 hours in total. I bought a genuine ballast on EBay but there are probably equally good ones for less money.
GENUINE Xenon Headlight Ballast Control Unit Module Fits Mercedes E 5DC009060-20
T
Tony sirett
Worksop
Thank you all, fuses are all ok, 99% sure it's the ballast now, just waiting for my icarsoft to get here then I will order one if it is the bit that's broken.
