Which Diesel?
Phil_Yorkshire
C320cdi
Hi, I'm not yet a Merc owner but I may well become one if I can find the right motor. I'm an ex mechanic and although its been a while, I do understand how engines work :).
I've owned a diesel car since 1988 and won't be swayed any other way. I live in the Dales and believe me, the MPG claims for petrols just don't stack up in these hills.
I've just started to look for a replacement for my current Alfa 147 jtdm - don't laugh, engine wise its been one of the most reliable motors I've even owned and goes like sh&%. Apart from a Volvo D5 I always had BM's before that but gave up on them when they ruined an excellent 2.0 diesel engine by putting a single cam chain at the back of the engine - the outcome of which was motor trade famous. The Volvo D5 was a brilliant engine but most use an auto box which again, is not really economically viable where I live.
I was attracted to the possibility of a Merc when I saw an Ebay ad for a 2013 C220 cdi estate at what looked like a very reasonable price. A little time spent on a few websites located several even cheaper ones - some under 100k miles with dealer service histories. However, I then googled the engines and found that much like BMW's of the same era, the OM651 engine that I believe powers the car I was looking at, has cam chain problems.
Some people seem to point to stop/start systems making things worse but from what I can make out, its much the same as the BM - down to the use of a single chain rather than the duplex used on older engines. Also like BM, putting the cam chain at the back of the engine makes repairs much more difficult - not good! I'm not prepared to take the risk of buying a car that in the near future may well need £1500 spending on the engine - if I'm lucky. So its looks like OM651 engined cars are out.
So, my question is - is there a good Merc diesel engine that doesn't suffer major problems fitted to models in the £6000 to £8000 bracket? The 320 cdi has been mentioned to me but I really don't have a clue. I also want a manual gearbox and they seem very rare on the 320's.
EmilysDad
Bury Lancs
ML350
.... The Volvo D5 was a brilliant engine but most use an auto box which again, is not really economically viable where I live.
Welcome to the forum Phil
but the vast majority of Mercs only have 2 pedals ;) and a lot of them only ever came with 2 pedals ;)
Craiglxviii
Cambs UK
The 3 litre V6 diesel is excellent. A 320 CDI after 2006, or a 350 CDI will do all that you want.
However, a 5.0- 5.5 litre V8 burning manfuel will also see the same real world fuel efficiency.
Also. Forget a manual. Go for the auto. They’re JUST THAT GOOD.
mioba
Nottingham and Köln
you will be hard pushed to find a manual.
I cant offer you much advise, otherwise happy hunting and keep is posted on the purchase.
SmartAmg
2011 E class coupe 350 CDI
Welcome, Phil, I'm a tad biased but, a 350 cdi E class is rather good. :rolleyes::):D
P
Phil_Yorkshire
C320cdi
Autos are out sorry. My D5 would return over 40 mpg regularly - not just on a run. However, that was not the case driving near home (which is most of the time) - I would then be lucky to see 12-15 mpg. Its the hills you see and the over revving that autos do on them.
Although....... maybe I could start using my van more and possibly look at an auto. I've heard the 7g box is problematic???
I was always told that the Mercedes manual is as bad as the automatic is good, and that the automatic is superb.
00slk
Cambridgeshire UK
2002 SL55 AMG, 2005 E320 CDi,
Hi Phil, welcome......have you driven a manual Mercedes diesel?
I've owned a 240d manual and a 280se manual, I like manuals too, then I went back to an automatic Mercedes and have never looked back ;)
Srdl
New Forest, Hampshire
GLC43 AMG 2018 (X253)
Hi Phil and welcome. The 3 litre engine is the one to go for, it won’t even notice the hills.
I would ask “have you ever driven a Mercedes automatic?” - the 7g is good, the new 9g is brilliant.
EmilysDad
Bury Lancs
ML350
do other countries have the same obsession over manual gearboxes that we seem to have here? I can understand why your average Eurobox is manual due to the generally higher purchase price of an auto, but when the car in question is a more expensive 'prestige marque' why would you want a manual?
My wife's uncle has/had a manual Jag and I managed to quite upset him when I suggested his must be a one off manual because why would anyone ever want one! :rolleyes:
M80
Derbyshire
Manuals are becoming more common on the MB, but the early one's were auto only as far as I know.
Your looking at post 2010, that'd be the 642 V6 3 litre, or the 651 2.1 litre.
They are both excellent engines but with gremlins that can bite.
The V6 is possibly more reliable but more thirsty.
The 2.1 is a simplex cam chain, that has very regular issues with tensioner and if not caught early stretched chain and worn timing gears (rear mounted so engine out).
In truth looking at your criteria it doesn't sound like a Merc is for you.
Then consider DPF's and later added ad blue and nox sensors (all designed to drain your wallet effectively) and your desire to stick with (modern) diesel might not be as attractive as you think.
In modern motoring conditions that we "enjoy" in this country I've no idea why anyone would want or need a manual. :confused:
Up and down the clutch in crawling stop start traffic... o_O
The days of autos being slower or less fuel efficient than manuals are long long long gone.
Gazwould
C250 CDI
Thanks to incredibly thin ATF .
malcolm E53 AMG
Welcome to the forum!
Cutting to the chase with your budget I would buy a C350cdi auto it will tackle everything the Dales can throw at it:
https://www.autotrader.co.uk/car-details/202011035753251?sort=price-desc&minimum-badge-engine-size=3.0&include-delivery-option=on&model=C CLASS&advertising-location=at_cars&radius=1500&make=MERCEDES-BENZ&postcode=le91ug&onesearchad=New&onesearchad=Nearly New&onesearchad=Used&fuel-type=Diesel&page=3
ps you will probably need winter tyres when the temperatures drop where you live as the car is RWD
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome Phil- I'd never go back to a manual - hills or not. Good advice on the 6 pot diesel.
Your comment on the Volvo D5 auto is spot on, I had one and it couldn't pull the skin off a rice pudding in the hills hence returning very poor MPG, but Mercedes (7g) boxes are a different league
Just checked autotrader for 320/350 diesel E class with non auto gearboxes , I can’t even use the M word ! :rolleyes:
There are 0 available
00slk
Cambridgeshire UK
I've just remembered, I had a 250 compact manual too........omg and a 220seb manual, this is so embarrassing, I've had so many cars I've forgotten what I've owned :oops:
P
Phil_Yorkshire
C320cdi
  • #19
OK guys, many thanks for all your comments.
Maybe I am behind the times on auto boxes + it seems that if I want a decent engine, I have to accept an auto box. However, there's quite a lot of adverse reports on the 7g box, people saying the old 5g box was much better but that would mean a much older car. Is the 7g box trouble or not? Regularly serviced, what sort of mileage is the V6 diesel good for?
I guess the only way I'm going to find out how good these autos are is to find a dealer with one in stock and blag a test drive ;).
