Which New tyres
A6lns
Northamptonshire 6
C250
Hi just looking on the internet need a new set on my c250 sport hankook or Goodyear f1 any views would be grateful
John Laidlaw
Wirral
Land Rover Discovery 4
Goodyear F1 for sure from those choices, a member on here was having horrible delamination issues with the Hankooks
Lots of members on here swear by Uniroyal Rainsport
I'd be tempted to Michelin cross climates if they do your size, they are amazing
A
A6lns
Northamptonshire 6
C250
Goodyears are good price well I don't think they are that bad but I will look at the Uniroyal rainsport i thought they was hard to get hold off
flowrider
SL500 (R230)
As John said Goodyear Eagle F1 AS3 are very well liked, also the Dunlop Sport Maxx RT2's and Uniroyal Rainsport 3's
stivesvelo
CAMBS
www.orientalexpression.co.uk
S210 E320 cdi estate
I would say 'avoid' the Goodyear F1.
I had a set fitted last year (S210 320cdi 17") after reading good reviews & can say that they are the worst set of tyres I've had & I've had a few in the 175k miles I've personally covered in this car (expecting 222,222 on the clock tomorrow), I had about 8-9 months out of them approx 12k mls.
What's wrong with them, basically poor mileage & uncomfortable/noisy with a bit of wear, grip was good however, wet and dry.
I had a slow puncture (came out to find a flatish tyre in the morning) & took the tyre in for repair to be was told it's irreparable as the pin was too near to the edge (which I accept is bad luck), however at the same time was told that it was also unsafe because the rubber was cracked & perished around the circumference between all of the treads, I checked the others & all are the same, it was suggested that I had been driving on under inflated tyres or they were old, neither was the case.
In the end I chose the best of them & asked the supplier to send it back to the manufacturer for assessing (this is some time ago so am waiting for some response).
In the meantime I've been using some 16" steel wheels with some old tyres, the ride/noise levels are so much better & also improves fuel consumption. Downside it it doesn't look too pretty so I'm looking for some sort of wheel trims that don't look like they've come from Halfords & thinking of putting a new set of 16" tyres on, will probably put Michelins on as they have been the best out of the lot & in the long run are most cost effective.
I'll let you know what they say in the end but am not a happy bunny as they weren't much cheaper than the Michelins.
Craiglxviii
Cambs UK
Rainsport 3's all round for me. The price from Camskill is excellent and I give full credit to Jon Bell here for persuading me with pictures of sharks :D The grip on those things is amazing wet and dry, they're quiet too. Not sure yet on how well they wear as the car has only done a few k miles with them on.
I have Pirelli P Zero on my 212, they are very good too. A mix of all seasons on my 215, but that will shift to Rainsports whenever I can justify it. They're just that good.
A.J.
Norwich. UK
I have Pirelli P Zero's on my C Class and compared with my old C Class which had Michelin Premacy's on it I do find them quite noisy.
However the current C Class does have a mix of 225's on the front and 255's on the rear which would probably account for a lot of the increase in tyre noise.
John Laidlaw
Wirral
^ I'm with you Andy, I find the Pirelli P Zero's noisy too (I can even hear them over the exhaust note ;)), they'll be replaced by Goodyear when the time comes- I'm surprised about the post above on the GY, never had any problems myself- I like Michelin too but they come with less tread to begin these days, and I need as much as I can get really...
Chrishazle
Nr Ashford, Kent
I also was surprised about the GY Eagle F1 comment above, I put them (17") on my S204 almost 2 years and about 15k miles ago and have been delighted with them - quiet, comfortable, grippy wet and dry, and still lots of life left in them. Admittedly I drive fairly gently most of the time (or I get earache from the passenger seat) but even so that seems good going!
drmw
Yorkshire
www.autonomed.co.uk
The only tyre noise you should be able to hear over the exhaust note is the screech of tortured rubber - you are clearly not trying hard enough.
A.J.
Norwich. UK
John Laidlaw
Wirral
Knew I was doing something wrong David!
BClassChris
PRESTON Lancashire
Mercedes B180 CDI (2009)
Carrying on with the point of this thread I have a B Class (I know you lot have C E &S Class) but I was wondering what I should throw on mine I've always been a fan of Michelin since I found I could get about 30k mile out of a set but that was on regular profile the B Class is a sport and I've never had low profiles before.
The tyres on it aren't my choice they are a mix of budget crap and hankook but they have that chevron shaped tread on em which I think makes em noisey is there anything you guys would recommend
PS I don't drive like I stole it nor do I drive like miss daisy and it's an auto if that means anything
TIA
JBell
Torquey
C350 CDi Estate (GAD Edition)
Goodyear Eagle F1 Assy 3 or Goodyear Efficient Grip
C350Carl
Middle East
BMW 740Ld xDrive
Top 3 that I've used and in order that I rate them.
Dunlop Sport Maxxx RT2's - Grip on par with Goodyear F1 Assy 3's and quieter.
Michelin PS4 (which is on my car now as the RT2's weren't in stock when I needed tyres and the PS4 were £20/tyre cheaper). On par with RT2 but not done enough miles to compare yet.
Goodyear Assy 3 F1.
All 3 give pretty much identical MPG and grip in my experience. RT 2 and PS4 about the same noise wise. A3 slightly louder on rough tarmac.
So of the 3 above then whichever is the cheapest will give you a good return for your money.
Craiglxviii
Cambs UK
Right now I'm running:
Pirelli P Zero Nero on the 212. No complaints.
Uniroyal Rainsport 3 on the 211. Epic in every sense.
A mix of Kleber Quadraxers and some Michelin All Season (forget name)on the 215. Disappointing noise wise.
A
A6lns
Northamptonshire 6
C250
  • #19
Hi I've just put a set off Goodyear F1 on my c250 sport they are not so noisy now I had a mixture of budgets and hankooks on mine horrible in the wet
Headhurts
Norwich, Norfolk
Mercedes GLC300 2021
I have Pirelli P Zero Nero on my E350 S212, they are on from new last year.
I have had no problems with them but as I have yet to change tyres on any of my Mercs it's difficult to compare.
I may keep this car so time will tell.
