john2006
- Jul 22, 2023
- C200/2008/1.8
Hi guys,
So I've been hearing this very quiet/soft (sometimes its there sometimes it's not...) high pitch sorta of squeaky noise.. coming from the steering wheel. I've been googling and youtubing quite a fair bit in hopes of finding the cause. I'm reasonably sure that the problem is not a failing pump or belt etc etc but rather a very weird....odd... issue with certain models whereby above the brake pedal, there is a panel, and under this panel is something that is known to rub against the panel causing this annoying noise. Whilst I know it could be other things... one thing I also wanted to check one final time and top up if nessesary is the power steering fluid. I checked it once before, and it seemed fine however I've tried checking it once again just yesterday and noticed on a warmed up engine the reading was directly on the minimum line for "warmed up engine" so this is also a possibility... but I'm not sure if the car was on totally flat or not so I will check once again on a flat service to be certain...
I cannot for the life or me find exactly what power steering fluid I should to top up with? and more importantly is it safe to add new fluid over the old? I've gone through my documents and I can't tell (as nothing states it has been done) that the fluid has ever been changed, and if it has, what fluid is in there (so I can match the same fluid).
I#ve checked halfords and they only seem to do one fluid for my car which is:
Comma MVCHF 1L (for vehicles CHF 11S and CHF 202)
But in the description it says things like:
I have no clue what is already int he car and what the grade is..to be even able to make sure I don't mix it...? so I'm thinking, don't buy this one... and look elsewhere but exactly what ones can and can't mix well with others? is it better to just get the garage to replace the whole power steering fluid ?
[EDIT]
I have a Petrol , Mercedes benz C200 2008 1.8ltr
- IMPORTANT: Do not mix with other grades of ATF or Power Steering Fluids.
[EDIT]
