Which Tyre? R230 SL350 - changing from 17" to 18" wheels
Alastairp
West central Scotland
2005 CLK200 coupe (now gone) 2011 R230 SL350 2014 C220 estate
I have OE 17" 5-twin-spoke wheels on my 2011 SL350 which I think are a bit "heavy" looking and difficult to keep clean due to the slot.
I have just pulled the trigger on a set of used 18" 5-spoke wheels (8.5 & 9.5 staggered) which I believe were an OE extra cost option:
I intend to have these refurbed, although I don't have them yet.
I believe that tyre sizes would be 255/40 R18 and 285/40 R18.
Is there any advice/ experience of current tyre recommendations for general (occasionally spirited) road use - i.e. no track antics - and general summer leisure cruising miles (no winter use).
I have read that the ride is compromised on Pirelli P-Zeros and that Kumho PS71/91 can be slightly out-of-round causing imbalance vibration a few hundred miles after balancing.
I will also need to work out if TPMS system will work, assuming sensors are still fitted on the used wheels - tyres are still on, but will be getting replaced anyway.
Thanks in advance.
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
The rear tyres need to be 285x35x18 to keep the rolling radius correct.
As shown in the diagram below showing your alloy and tyre combination.
I can recommend Falken FK520 tyres for a good mid price tyre.
I'd choose Goodyear F1 Asymmetric 6 given the choice of all tyres. They were superb on my E63.
Look at Asda tyres for a decent price whatever you choose. All in price and you choose a local fitter.
Monkey Wrench
I Fancied a CLK, bought an SL350
Thanks in advance.
I too prefer to cruise around in summer, (Captain Slow they call me :)), preferring a 2001 Toyota Rav4 for the rougher weather etc. I have same size wheels, but my rears are 35, not sure why, bought it like it, but does make her look level, replaced the rears last year with Yokohama Advan Sport, they feel polite with low rolling resistance and repond when asked to get a grip, tyre just proud of the rim and only small weights needed to balance them. Pleased with my purchase.
A
Alastairp
Rears do indeed need to be 35 profile - sausage finger typo!
Will look again at Goodyear F1 Asymmetric 6 - didn't think they were available in 285/35/18 when I was browsing earlier
A
Alastairp
Falken FK520 also don't seem to be available in 285/35/18, although 510 may be
Monkey Wrench
I would have gone for the Eagle A1's, but I couldn't find them at 35
A
Alastairp
Falken & Goodyear not available in the required 18" rim size for both front and rear.
Current choices available in required sizes are as follows:
Kumho PS71 Ecsta front & rear £494.10
Kumho PS71 Ecsta front & PS91 rear £506.10
Uniroyal Rainsport 5 front & rear £562.70
Pirelli P-Zero front & rear £670.00 (MO)
Yokohama V105 Advan Sport front & rear £723 (MO)
Any advise/ recommendations from the above or any others that might be available would be appreciated.
Monkey Wrench
Check out the tread wear rating, a big difference might help you choose
A
Alastairp
Bugger!
Wheels just arrived - all four are 8.5J not 8.5J & 9.5J as described.
Just packing them up now to send them back.......
Back to the drawing board.
Maybe the twin spokes will just have to do for now.
A
Alastairp
Looking here:
.....it would appear that 8.5J x 18 ET35 front and rear was a standard OE fitment, so I don't need the staggered setup with 9.5s on the rear.
This would make tyre selection easier and wheels could be swapped around if necessary.
Anyone running this arrangement?
A
Alastairp
So, on the basis of 255/40 R18 all round the choice seems to be as follows (in ascending cost order):
Kumho PS71 Ecsta £452.40 - Labelling: D - A - 73dB
Uniroyal Rainsport 5 £523.20 - Labelling: C - A - 73dB
Pirelli P-Zero £663.00 (MO) - Labelling: D - B - 73dB
Goodyear Eagle F1 Asymetric 5 £687.00 (MO) - Labelling: A - B - 71dB
Continental Premium Contact 6 £715.20 (MO) - Labelling: C - A - 73dB
Yokohama V105+ Advan Sport £726.40 (MO) - Labelling: E - A - 73dB
Michelin Pilot Sport 5 £812.60 - Labelling: C - A - 73dB
My head is spinning with tests & reviews.
Based on experience, where would your money go?
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
I have used Kumho in the past a good tyre but wear quickly.
I am currently on Rainsport 2's on the front & 5's on the rear on my E350CDI, very pleased with both.
JBell
Torquey
C350 CDi Estate (GAD Edition)
JBell
Torquey
One of these 2
A
Alastairp
  • #17
The rear wheels will sit a long way into the arch
The 18s I am fitting are the same offset as the existing 17s - ET35.
The only difference is the wheel diameter and tyre profile.
Having watched the review video above, albeit on a front drive car, I am leaning towards the Goodyear Eagle F1 Asymmetric 5 for price and rim protection reasons. Performance wise, there doesn't seem to be a big difference.
JBell
Torquey
They both have good rim protection.
I have used both and recently went back to the RS5 from Eagle F1 Assy 5 on the rear. The RS5 is better in cooler conditions and the wet.
There is now an Assy 6
sonic
Staffordshire
I drove through Austria a couple of years back on very wet & smooth tarmac roads. The front RS2's were fantastic.
A
Alastairp
  • #20
Yes, but not available as 255/40-profile in R18 - only 255/35 or 255/45.
So you would recommend the RS5 over the Assy 5, notwithstanding the saving of more than £40 per corner.
We only have cooler conditions and wet up here in Scotland.
Thanks for your input JB.
www.ckinsurance.co.uk
