loz_dormer
- Oct 10, 2018
- ML270
Morning all, ML270 CDI 90k Miles,
I’ve got a whine/drone from when pulling away right up to around 40mph they it can’t be heard. It’s more noticeable when coasting along on a smooth Road and sounds very central.
I’ve had the car in the air and there’s nothing obvious, unfortunately you can’t seem to turn the ABS off to drive the car on a ramp to determine the location.
Ive changed both front and rear diff fluid with no change to the noise.
I suspect it’s the prop bearing or the gearbox but have no real way of proving this,
Any one had the same noise and had it rectified?
New prop bearing kit from merc is £180.
