My wife owns a 200slk registered in 2000 with 60,000 miles on the clock. It has a 6spd manual gearbox. She loves it to bits.
Over the last few days it has developed a noise when you take you foot off the accelerator and is audible at low speeds (i.e. 30mph). Once the car comes to a stop the noise stops. When you put it to neutral the noise remains. When you drop the clutch and keep in gear the noise remains.
At first I thought it was wheel bearing. However a independent garage found no faults with the wheels. On closer inspection the noise may be coming from the behind the engine - but I'm not 100% sure.
It sounds like a dull metallic scraping noise and almost like a whining noise.
Can anyone help out. I have it booked it a merc dealer tomorrow morning.
thanks
thanks
