jberks
- May 12, 2004
- Jaguar XF 3.0 S, LR Freelander 2, Fiat 500 & Fiat Panda
I'm getting short of ideas now. Had my tyre refitted and resealed 3 times now but it keeps going down. Last time I thought we'd sorted it. Actualy found a small leak so refitted and filled with nitrogen and 2 days later it was still on 32psi. Bingo.
1 week later it was back down to 23psi :-(
So, ...it went back again today. I asked them to check for a leak and if rim corrosion was the cause, to just get the damn thing reconned.
They couldn't find a leak again so pumped it up to some silly pressure and left it all dayto see if it would seep. It stayed rock solid, didn't drop a lb. So they removed the tyre again and rechecked the rim for corrosion. 100% perfect.
They've refitted it again and I'll pop it back on tonight, but I'm not optomistic.
Given that it's fine on test, and apparently not leaking, the only thing I can think of now is that the tyre is somehow moving under load so it's ok stood in the garage or parked but lob it round a few corners and roundabouts and things start to go pear shaped.
Anyone had experience of such things?
Any other ideas?
help
Any other ideas?
help
