AMck
- Jul 3, 2008
- Location
- Newport
- 2007 E320cdi S211, SL320 2000(written off), Lotus Excel
Hi, I am pretty new to Mercedes ownership having just bought a 2000 SL320.
I'm pretty sure there is a problem with the brakes - possibly the servo and would be grateful for comments.
I also have a slight pulsing on the brakes, but I am sure this is a warped disc, both the front and rear discs are close to their limit and the rear pads are well worn.
If I slow down with reasonable but steady pressure on the brake pedal all seems well, but if I then need to quickly apply more force the pedal seems to go hard and I have to press very hard to get any extra braking.
Also when initially pulling off my drive after starting the car if I apply the brakes they seem hard and pretty ineffective taking almost all my effort to stop the car moving when in drive and without my foot on the accelerator, but as the engine is cold it is at fast idle.
I have put my foot on the pedal when starting the car and it goes down as the servo kicks in, but if I rev the engine it pushes the pedal back up against my foot. I have tried to listen for any leaks under the bonnet but can't hear anything. In the car if I keep my foot on the brakes I can hear a constant hissing from around the pedal area.
Also after turning the engine off it only takes 1 press of the pedal to exhaust all the vacuum and lose any assistance.
Does this sound like a possible leak in the servo diaphragm? If it is is it possible to strip and repair the servo or will it need a new one? Does anyone know of a repair kit or the part numbers of a replacement servo?
