- Aug 4, 2016
- Location
- Sunny Essex
- W211/E320cdi/2009 and CLK200k 2009
Hi Folks , just had a pleasant drive in good weather for 200 miles back from Sheffield and the Peak District . Only problem was that the car was in limp mode , a situation which has shattered my long held belief that a shiny car is a healthy car .
The problem started on the drive up , the car suddenly dropped to maximum revs of something like 1500-2000 . A quick turn off and re- start did sort it for a few minuites but it was then back in limp mode (this happened 6 weeks and 1000 miles ago , when the turn off and restart worked with no reoccurrences ) .
Reading the codes with icarsoft MB2 , showed the following code
P0244 Turbocharger/supercharger waste gate solenoid A Range/performance .
The only other dtc is an existing one I can't delete which is 2510-000 .
Probably nothing to do with this but 4 weeks ago I cleaned the exhaust back pressure sensor with spray cleaner , replaced the MAP sensor and sprayed a can of Wynns turbo cleaner through the turbo . Replaced the cars Lambda/oxygen sensor . I did all this because of the "glitch" 6 weeks ago . The car drove 2-300 miles since this with no issues .
Any areas I can look into more myself with this fault ? I was thinking the turbo actuator to look for any broken/overheated connections . There is some actuator arm movement when the engine is revved in limp mode , but I don't know if this is normal full range movement ?
The exhaust tips look a lot blacker and the mpg has dropped to late 30's for the motorway journey .
