The offset for W211 is 35-42,check offset of wheels first should be marked on inside,go to/ alloywheels.com/it may give you some idea.
AMG 5 spoke are 18" for the SL I have 4 sitting on the wall
But are they the correct offset for your wall?
Russ
I suppose that I could always re build it if the off set is in the wrong place
Russ
And, do they also have the rather nice valve caps?
I dont think that these have any valve caps
That's a bit sloppy for you isn't it Malcolm?
